Signs that an altenator is failing
Old Jan 14, 2005 | 07:31 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok guys, I have a digital voltage readout on my car and when it goes below 10.7 it starts beeping that something is wrong.
So I started my car up today, and it had a nice 13.3 volts, then all the sudden whammo beep beep beep, the car voltage was at 10.6-10.2, so I drove my sister to school with the bad voltage, got as close as I could to the house as I could, maybe 1/4 mile and the voltage came right back.
It has been doing this periodically but never power gone for 20 minutes of driving, or more, so, is this the alternator? I already took it out; it’s a lifetime guarantee from AutoZone, and its only 2 years old. This sucks...
Anyways, if it’s the alternator, what are possible causes of one dieing?
DO they just quit working, or do they do what mine is doing, work, then don’t work, then work, and so forth.
I mean the stocks lasted what 10 years maybe, this newer one lasted 2, and how does AutoZone make money if they replace them so often?
Anyways, help me out here,
Thanks,
Shane
Old Jan 14, 2005 | 07:57 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
https://www.thirdgen.org/techbb2/sho...hreadid=274571
Old Jan 14, 2005 | 09:24 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
One thing that many people overlook is the battery in the digital meter itself. If this is starting to die then it can give incorrect and sometimes wildly inaccurate readings
Old Jan 14, 2005 | 09:59 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if you have a lifetime warrenty on the alternator then just take it out and have them test it and see if its good that would be the first thing to do then also have your battery load tested to make sure it is also good
Old Jan 14, 2005 | 10:05 AM
91Z28-350's Avatar
Re: Signs that an altenator is failing
By getting you to go into the store (that's always the first step of staying in business), and if it tests fine, by getting you to buy a bunch of other stuff too. Autozone stuff isn't the best in quality, but with the lifetime warranty, you keep going back and back. It just gets annoying if it breaks down on the road repeatedly. Rebuilding an alternator isn't overly expensive, if you're in the parts business.
Get the alternator and battery tested at autozone. If either are bad, replace and see if the problem goes away.
Old Jan 14, 2005 | 10:18 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Old Jan 14, 2005 | 10:31 AM
bru333's Avatar
Car: 1987 Camaro SC
And if you would read and search before you post, you would have seen that thread from kretos from tuesday about an alternator problem.
Old Jan 14, 2005 | 10:38 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by bru333
And if you would read and search before you post...
:no:
He does not know the meaning of those words used in such a conjunction.
Old Jan 14, 2005 | 10:39 AM
bru333's Avatar
Car: 1987 Camaro SC
I know. I've been following the saga of therckid for a while...
Still you have to hope that one day...
Old Jan 14, 2005 | 10:42 AM
THEGENERAL's Avatar
no he is like a bad case of herpes they just keep coming back again and again with no chance of ever getting rid of them...
Old Jan 14, 2005 | 10:45 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Um... Yeeaaaa..... don't know about that. Is that something you get with a poser color tattoo?
Old Jan 14, 2005 | 10:48 AM
THEGENERAL's Avatar
OH man that was harsh ...
No i was just going by what your ex told me....
shane did you ever get your new alternator on yet ????
Old Jan 14, 2005 | 10:50 AM
bru333's Avatar
Car: 1987 Camaro SC
Iunno...
Dood...he posted on that other thread that he just got a new "alenator"...what the heck is that? Do you get that with herpes? Or is that what causes them?
Guess he won't be coming back to this thread anytime soon...
Old Jan 14, 2005 | 10:55 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I told her that mexican dude was trouble. She wouldn't listen. So I take it she fell in with the disreputable crowd in IL huh? Can she still tie cherry stems with her tounge?
Iunno...
Dood...he posted on that other thread that he just got a new "alenator"...what the heck is that?…
Let's see... umm...
Old Jan 14, 2005 | 10:57 AM
bru333's Avatar
Car: 1987 Camaro SC
Old Jan 14, 2005 | 11:56 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
yeah guys new altenator is in, while i did that i went ahead and changed the oil also, and now the voltage on ym meter reads a steady 13.8-14.2 volts at idle, this is awesome.
They didn't even check the altenator i broguth in, just opened up a new box and handed me it and took the old one. I figured the battery is perfectly fine strictly becuase i drove close to half an hour on the battery alone. Batteries dont normally last that long if they are bad. Plus the battery has a what, 7 year warentee through some company, and its only been in for 2 years also, if it goes bad i'm in good shape as well...
Take it easy.
Shane
Old Jan 14, 2005 | 12:11 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
try searching
Old Jan 14, 2005 | 01:01 PM
thecoolone's Avatar
Car: 89 GTA
https://www.thirdgen.org/techbb2/sho...ight=altenator
https://www.thirdgen.org/techbb2/sho...ight=altenator <-- LOL
Yep. Bored today I am.
Old Jan 14, 2005 | 01:08 PM
THEGENERAL's Avatar
wish shane would get Bored sometimes and do the same as you just did for him ...
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
