Engine Knock
Old Jan 15, 2005 | 12:44 PM
typhooey's Avatar
Car: 1992 GMC TYPHOON #1796
Engine: 4.3 TURBO
Engine Knock
IS THERE ANY GOOD GM GUYS OUT THERE THAT CAN HELP ME WITH MY ENGINE KNOCK THAT LIVES IN NY.
Old Jan 15, 2005 | 02:29 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Shhhhh, everyone can hear you just fine if you type normally.
Old Jan 15, 2005 | 02:47 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
You'll probably need a rebuild.
If you can do it yourself, it'll be cheap, if you can't, then having a new engine installed might be the best route.
Old Jan 18, 2005 | 06:33 AM
typhooey's Avatar
Engine: 4.3 TURBO
thats easy to say but all the guys I talk to that own these trucks say that this is a common problem due to an ignition problem or in the timing so before I rip out the engine id like to be 100% sure that it is the motor
Old Jan 18, 2005 | 07:16 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
http://www.gm-trucks.com/forums/
Why don't you try this other forum for trucks.
This one is for 3rd gen f-bodies only.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
