Won't Run AGAIN
Old Jun 20, 2001 | 05:08 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Won't Run AGAIN
OK this car is killing me. It will not run when I try to start it, however If I hold the Throttle Blades open and hit the starter it will. As soon as I let loose of the Throttle it will die right now. It has a new IAC and TPS but I will take any idea.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 20, 2001 | 09:05 PM
btt.........I need help
Brian
1989 Camaro RS
Old Jun 20, 2001 | 09:47 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
is it possible that the throttle blades are closing completely? I don't think they should. I think there is a small adjustment screw on the throttle body that is hidden by a plug. I think you can carefully drill the plug out and adjust the blades open like on a carb. I'm not sure though so somebody else may tell you different. Hope this helps a little.
Old Jun 20, 2001 | 09:50 PM
slayer2000's Avatar
Car: 1990 GTA
sorry,I though you had tpi for some reason. But you could still check to see if the blade are closing completely.
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
