car running and idling rough
Old Jun 20, 2001 | 04:30 PM
KYL98's Avatar
Car: 1991 Z28
Hey guys, Im a new third-gen owner. I recently acquired my dads 91 Z28 L98/700r4. It has 81,000 miles and runs great. I recently did a tune-up on it(bosch platinum plugs, Standard wires, Cap and rotor, and coil). The problem with it is, after the engine warms up, it starts cutting out, usually under a load. If you drive it easy, its fine. I was thinking maybe fuel delivery, but wouldnt it do it All the time, not just when its at operating temp??? I also replaced the TPS sensor. I did the coolant bypass mod on it recently also, could that have anything to do with it??? I also have been told it could be vacuum or the O2 sensor. Please help, Im running out of possibilities. Thanks in advance....
Mike Estep
1991 Z28 5.7tpi stock except for 3in flowmaster exhaust with 2 high flow cats, and the tb coolant bypass.
Old Jun 20, 2001 | 09:45 PM
SGT SWEETPANTS's Avatar
Vacuum leaks and timing could both cause your problem. Checking these would at least be a good place to start.
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter, Hooker Super Comp Shorties and Y-pipe, Catco Converter, Flowmaster 80 series, 3 inch custom exhaust
Old Jun 21, 2001 | 08:22 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check your fuel pressure while the engine is running. Your problem CAN be due to a faulty fuel pump.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
specialized
Jun 18, 2022 09:26 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
