HELP! why is my gas tank leaking??!!!!
Old Jun 15, 2001 | 04:41 PM
Tas's Avatar
Tas
my sis filled it up this morining. I went outside today and I smelled gas. I didn't think much of it just seeing a 70's truck drive by. I figured it was that thing. when I came back home from lunch, using another car, I still smelled it and noticed a puddle under the back of the car. I then looked under it to see drops coming down off the back left heat shield. I smelled it and, yup, it was gas.
What to do now???
-Tas
'89 Formula WS-6
Old Jun 15, 2001 | 04:46 PM
ShaneBuss's Avatar
I know there is a recall on the fuel filler neck. not sure what year models it applies to.. Anyone know?
Shane Buss 92 Firebird 355, Holley 800 Double Pumper Carb, Vortec 1.94/1.50 Heads (Ported,Polished,Milled .025), 10:1 Comp Ratio, Cam Specs 224/234 498/520, 1.6 Roller Rockers, Hooker Headers, Flowmaster, !Cat, 3.73 Posi, Msd 6A Ignition Cyb. Speedo box, Single Plane Intake
http://users.ev1.net/~sdbuss/index.html
Note all girls on web page are x's, and will be removed when i get more time
WEIAND SUPERCHARGER REMOVED
2001 LS1 Trans AM A4. Bone Stock. 3.23 Rear End
Old Jun 15, 2001 | 04:49 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
the recall is for 89-92 cars.
Don't fill up completely,and you're fine!
Old Jun 15, 2001 | 05:06 PM
Tas's Avatar
Tas
where are the cracks? can I still take it in for the recall? does it have to be a Pontiac dealer for my Firebird or can I take to to the Chevy dealer which is much closer?
Old Jun 15, 2001 | 05:29 PM
Tas's Avatar
Tas
Crap. there is no open recall on it. so I guess I'm on my own to find it and fix it
-Tas
'89 Formula WS-6
Old Jun 21, 2001 | 07:22 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Try sanding around the area where the filler neck and down tube connect (if this is where it's leaking) and get some of that epoxy putty (Quicksteel, Bondo, ect..) and put that around there.
Epoxy putty is the best invention...
My car had a 'full tank leak' that was caused by the o-ring where the sending unit/pump goes into the tank. It appeared pressure or something pushed the o-ring out on one side.
Old Jun 21, 2001 | 08:28 AM
mrgto's Avatar
It is from the neck. The neck seperates from the tank and that is where you will see it leaking.
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
jer4251
Sep 1, 2015 09:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
