One last question, Having temp problems.
Old Jun 20, 2001 | 01:09 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
I have a 160 therm, new water pump, air dam is there and all. Why does my car heat on the highway on warm days? What should I set my timing at for a TPI 350 running the 86 305
ADS superchip. Right now my timing is set at 10 degrees with the current setup. is that too much? It is not spark knocking and I am using my old 305 knock sensor wothout any apparent problems.
Any suggestions?
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old Jun 20, 2001 | 01:27 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
What temp are you running? Have you verified the guage reading vs. Auto X-ray reading? Guage could be off.
Old Jun 21, 2001 | 07:48 AM
KustomIroc's Avatar
Engine: 383 Stroker
I think I figured it out.......I am running the ram air with 8 inch dryer vents from the fog lights in front of the rad and into the air intake. I am assuming that this is blocking 90% of the air that usually goes through the fog lights. Does that sound resonable??? As it heats on the highway but not town or city driving.
Jamie James
1986 Iroc-Z 305 TPI
My IROC:
Old Jun 21, 2001 | 08:33 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
<font face="Verdana, Arial" size="2">Originally posted by KustomIroc:
</font>
I think its possible but I dont think that's the only issue. Look at trans/ams, they don't have any grill vents. Its' all from the bottom. Take one out and see if it makes any diff.
Bstrang6
Sep 8, 2015 04:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
Fronzizzle
Aug 9, 2015 01:15 PM
