Trouble code 33 and a rough idle
Old Jun 20, 2001 | 11:58 PM
AFRO IROC Z's Avatar
I just recently got a code 33 on my 87 iroc 305 tpi. How do I go about diagnosing the problem and fixing it. Also my car idles very rough when i first start it and smooths out a little once it warms up, but it still fluctuates. Sometimes it has to crank for a little when trying to start it(hot or cold). I have cleaned the iac, set the timing, new plugs, wires, cap and rotor, new coolant temmp sensor, and new oxygen sensor. None of these things helped. Hope someone can help, Thanks.
Old Jun 21, 2001 | 09:16 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
This would indicate a bad MAF. You can get a rebuilt one for about $139.00 exchange.
BEFORE you do this I would replace the MAF Power Relay and MAF Burnoff Relay. This would cost about 20 bucks for both relays.
It might on a longshot solve your code 33. If it doesn't and you have to get a new MAF it isn't wasted money on the relays because it's a good idea to change them with a new MAF.
PS.... check the MAF connections first to see if they just came unplugged or have been damaged.
[This message has been edited by MikeInAZ (edited June 21, 2001).]
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
JHX
Aug 29, 2015 02:30 PM
