383 Strokers
Old Jun 21, 2001 | 02:14 AM
chevySS's Avatar
383 Strokers
Do 383 strokers make their power on low end or high end RPM's? I was toying with the idea of a 383 with TPI but if the stroker made it's power on top end it wouldnt be a very good combo would it? Just wondering.. I always thought they made the power on low end, but my cuz said they make the power in high rev. I could quite possibly be wrong.. so any response is appreciated. Thanks in advance!
Old Jun 21, 2001 | 02:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The long stroke gives it more torque but makes it harder to spin at high RPM.
Old Jun 21, 2001 | 05:29 AM
FAST LiFE's Avatar
The 383’s make great power at low speed RPMs. As far as top end power, it really depends on how you build it. A 383 Superram (fully ported) motor pulled up in the 6000’s. A Minirammed 383 I built for a friend pulled to 6800 RPM. Wear and tear on both motors were really good, but a lot of thought and invest in parts helped with that longevity. Lingenfelter has built many 383’s that have ran 12’s and 11’s in the quarter and ran 180+ MPH with out problems. 180+ MPH is a lot to say about how well the top end is on 383’s. Going with a good engine builder/machinist is the key. Harder at spinning at high RPM? Only if the guy that built it didn’t built it right.
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
Old Jun 21, 2001 | 12:37 PM
chevySS's Avatar
Thanks for the help guys
Old Jun 21, 2001 | 01:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe I should say "more expensive to spin at high RPM".
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
