WhaT Is The TCC Lockup?
Old Jun 20, 2001 | 08:19 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
What is the TCC?? How do I know if it is working on my car? Is it the overdrive??
Mike
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jun 20, 2001 | 10:38 PM
Enkil's Avatar
It's referring to the torque converter. While I'm not sure what TCC stands for, I can only guess something like torque converter clutch. heh.
ANYways, it's not overdrive. The torque converter is the automatic transmission's version of a clutch, essentially. It lets the engine spin when the back wheels don't wanna; it's how the engine can be running while you're at a stoplight.
But that's not very fuel efficient. Since there is no direct connection between the engine and the tranny, only a fluid-filled space, there's some slippage, and loss of efficiency. To combat this, they made the torque converter lock up, via some form of a clutch, that does directly connect the engine to the tranny, so there isn't any slipping.
Torque converter lockup occurs after 35mph. Every time you hit the brakes, the torque converter unlocks, so the car doesn't stall when you come to a stop. That's also why, if you ever paid attention, if you're driving at about 50 mph, and have to hit the brakes for a second (for a turning car, for example) the rpm's are a bit higher than they were a second ago, and then drop down some.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 21, 2001 | 06:42 AM
Engine: ZZ4 - 350
Thanks Man! I am just trying to see if it is working. Because I am not too sure about the gas mileage I am getting. I will get a better Idea on this tankful of gas, since I have been driving like an old lady. LOL
But I was told that if the TCC wasn't working, I would get some poor gas Mileage. I will try what you were saying, and pay attention when I hit the brakes.
Thanks again!
Mike
Old Jun 21, 2001 | 07:26 AM
Biochem's Avatar
Car: 2002 SOM z28
When the converter is slipping (ie- the TCC is not locked up) there is a larger amount of heat produced and you may burn the fluid. When you go with a higher stall converter (basically one that doesn't lock up until a higher rpm) it will generate a bit more heat and you'll be a good canidate for an aftermarket cooler. I would suggest one anyways after having seen how small and in-efficient the stock cooler inside the radiator is!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jun 21, 2001 | 09:13 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
A bad coolant temp sensor will prevent closed loop operation and prevent TCC lockup which will basically send your MPG to squat.
It's a longshot but you would get a code 15 I believe it this were happening. Happened to me and I didn't know it. (SES light burned out).
Old Jun 21, 2001 | 02:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's a variation on that way of checking... keep your right foot steady on the gas, and tap the brake pedal lightly down with your left- just enough to turn on the brake lights. You'll see the tach jump up a few hundred RPM... release the brake, and the TCC solenoid will go back into lockup, and the engine will drop a few hundred RPM.
With this way, since you've always got your foot on the gas, it's easier to notice the TCC lock & unlock.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 21, 2001 | 07:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
TCC = Torque Convertor Clutch.
Mine hasn't worked since I got the car running. I average 19-20 mpg commuting, ~24 highway. If that sounds terrible, then I guess I'd better get that TCC working (in the plans, just not immediate).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
seiplentz
Aug 19, 2019 06:02 PM
92camaro350cci
Oct 14, 2015 09:29 AM
customblackbird
Oct 1, 2015 04:30 PM
ramicio
Sep 28, 2015 01:18 PM
