setting engine timing
Old Jun 21, 2001 | 10:31 PM
B4Crisi's Avatar
How do I set the timing on my engine with a mild cam? It's advanced about 35 degrees, and dies when I put it in gear.
Old Jun 21, 2001 | 10:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you still have the EST controlled distributor, you need to disconnect the EST bypass line, and start at the factory setting (6 or 0* BTDC depending on TBI or TPI) to start, increase the timing in 2* increments until you get it right.
BTW, how do you get it to start at 35* BTDC...I'm assuming that's where the base timing is at? Must be turning over real slow?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
