383... JE, Trick Flow combo
Old Jan 19, 2005 | 11:35 PM
matts90firebird's Avatar
ok guys, here is a 383 ive been building, when ever i have extra money around, i put some into it......
2piece 4 bolt main 350 block bored 30 over, completly straight, and blue printed
Je Pisons -30 cc dish, nitrous rings
h-beams eagle
havnt picked up the crank yet most-likly forged 3.75
for the heads i scored a set of trickflow, wedge 64 cc heads, good valves and springs,
I need choise for intake, carb, and cam slections.
the engine is most likly goin in my 81 z28, its most likly duty will be strip, with a tint of street to it, i might go cruising every now and then. let me know what you think
if this helps any the trans in the car is a muncie rock cruncher, with 4.10 rear gears
thanks in advance
Old Jan 21, 2005 | 08:17 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
750 carb
victor jr intake for sure
LT headers, atleast 2.5 dual all the way back
compcams 288 or the next one up....
although, what is the intake runner volume on those heads? i hope its at least 200....
i run the above combo on my 350 with trickflow TFS-30400007-CNC heads, and it put out 430hp, 406ftlbs, with pretty, unexpectantly GOOD curves.... the 383 should help out that torque number too!!
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
RS Reaper
Sep 27, 2015 07:04 PM
