Difference betweeen 305 and 350 dampners?
Old Jun 22, 2001 | 05:28 PM
james_fearn's Avatar
is it OK to use a 305 dampner on a 350?
what is the difference?
All the catalogs say "small block" so at face value they don't seem to be distinguishing between a 305 and 350.
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jun 22, 2001 | 06:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes a 305 damper will work on a 350, as far as working goes. However, the ones that come on 350s are larger and heavier, and therefore more effective, at damping vibrations.
Even within 350 ones, there are quite a few variations. Late 60s-early 70s ones on high-perf motors like the LT-1 were 8"; ones on most cars after the motors became so limp all through the 70s were 6¾"; and then there are the timing mark variations. Of course, when you're working with a genuine race motor either you don't really care what the timing "number" is because you have nothing to compare it to, or if you do have a reference to compare your actual to, you use timing tape.
ICON Motorsports
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
