Computer Codes
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Computer Codes
Ok I went to the tech section and was following the route to read the codes. I used the 6&12 pin and the 5&6 but the ses light just stays on. (the car is running rich...backfires in the TBI when you hit the gas fast not when you go slow. Car has little power.)
HELP!!!!!!!!!!!!
Brian Felts
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
HELP!!!!!!!!!!!!
Brian Felts
1989 Camaro RS
Guest
Posts: n/a
I hope its that the terminals arent connected with whatever you are using...
Borrowing a couple pics from Vader here
Its the top 2 on the right you want to connect together, I assume thats what you were doing connecting 5 and 6. Make sure you have a good connection between them and it should start flashing the light... if not, the wiring has a problem or the ecm could be bad. Does the SES stay on all the time, or just sometimes?
Yes those are the connectors I am using. The ses light stays on all the time. I have no egr or smog crap however fastchip took those out of my prom.
More info the other day it would not idle when I let the throttle close it would die. I just turned the idle screw and it worked.....Could I have masked a bigger problem.
Brian
1989 Camaro RS
Brian
1989 Camaro RS
BumpaD82
Feb 26, 2016 02:57 PM
