choke and idle problems
Old Jan 22, 2005 | 09:58 AM
irocbadboy's Avatar
Car: camaro and gmc sierra
Engine: 5.0 l t.p.i,and 4.3 vortec
Transmission: manuel(iroc)automatic(other)
Axle/Gears: 3.45 bw
hi!my car wont choke and idle when is cold, but is corect at normal temperature.my car is iroc-z 1988 with 5.0 liter t.p.i auto.please help!
Old Jan 22, 2005 | 12:24 PM
Vader's Avatar
There is no choke on a TPI system. The ECM adds fuel for startup and cold idle based on coolant temperature. If the temperature sensor is defective, or the Idle Air Control cannot operate due to damage or contamination, you can experience hard cold starting and poor cold idle.
Old Jan 23, 2005 | 09:44 AM
irocbadboy's Avatar
Axle/Gears: 3.45 bw
Re: choke and idle problems
ok,I am sorry,it's not a choke,but on an injection engine,the rpm is more raised when he is cold,and it does not do it.I have changed the coolant sensor and adjusted the i.a.c sensor,and it is not better.
Infested
May 22, 2018 11:56 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
