305 HO engine exchanged,I suspect they used the non-HO cam in new block..
Old Jun 23, 2001 | 01:48 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I know,I should have just got a 350 while I had the chance,this was a quality reman long block exchange, not from autozone or something, I had it proffesionally installed, I think they might have used the incorrect cam at the reman. shop because it doesn't seem to have as much ballz as the old 5.0 HO did. it runs great but seems a bit weak into the 2500+ rpm range,kind of unusual considering it's got 5k miles on it. is there any way of knowing for sure with out taking it apart? it will have a new cam by the end of the summer so I will find out eventually.if it does turn out to be the wrong cam,I can say something about it,but that will most likely void my warranty. thanks
Old Jun 23, 2001 | 03:55 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The HO motors had more compression then the standard 305. You may have lost some in the swap.
Checkout the timing curve... you might need to do some tuning.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited June 23, 2001).]
Old Jun 23, 2001 | 07:33 PM
Bort62's Avatar
comp XE262H
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
