Fuel pump, fuel presure reg, fuel filter, just plain dirty injectors????
Old Jun 22, 2001 | 07:25 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
I was racing my fiances dad this morning in his 79 mustang needless to say I stomped him and I had a case of the DUH I NEED GAS it was alittle over the empty line so I hit the brakes and turned to the crossover and It died. This has happened to me before but it hasn't taken this long to get it to start. Normally I can wait 5 minutes of so hit the gas and crank it over well not this time every 5-7 minutes for 30 minutes and it still wouldn't start so he happened to come back the other way and help me push it across the highway still wasn't able to start even with ether aka starting fluid. It was getting spark and all. It just wouldn't turn over. You could smell gas just wouldn't turn needless to say 45 minutes later after i anitially killed it he took me to work and now 8:30 hours later it started right up with a minor tic noise till i hit the gas and i went away??
it is a 87 2.8 mpfi I've been meaning to change the filter and add stp ficleaner but haven't yet.
I have also ran a code 54 (fuel pump voltage) but no help so far on what the hell it could be. So please help I really cant aford the time or money to change the pump please tell me its just simple as the filter ie been at least 3 years since new filter
just never thought of the filter
1987 Chevrolet Camaro
2.8 Ltr HO Cut air boxes K&N Filters Gutted Cat (Did I say gutted opps don't tell the officer)
Duel catback Exhaust With Flowmaster series 80 dual 5"X24" MONSTER Echos
225/60/R16 Mounted on 97 Firebird 16X8" Rims
Old Jun 23, 2001 | 06:25 AM
michael's Avatar
Car: 1991 Formula
Does no one know what is wrong??
Old Jun 24, 2001 | 12:28 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Well, yea change that filter. That way you could eliminate one cause. Hmm..it sounds kinda like you did in fact run outta gas, then there was nothing for the pump to suck so you were dry firing the engine and the pump wasnt sucking anything and possibly you damaged the pump. When you started it later, did you use starting spray? Did you fill with gas right away?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
Old Jun 24, 2001 | 08:16 AM
michael's Avatar
Car: 1991 Formula
Nah I had enough gas to probly drive another 50 miles or so I got back after work and it fired right up no hitting the gas or nothing is it possible to vapor lock our mpfi?
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
