Need info on these heads immediately!
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Last 3 numbers - "059" - are those the fame'd "Vortec" heads that everyone is swapping too or some other head?
EDIT IN: It appears they are... but have the smaller valves. If you had the chance to buy them for $25 plus shipping, would you? Can they be machined for larger valves?
Thanks.
Thanks.
Car: 1983 G20 Chevy
Transmission: 4L60
Essentially the same thing as 350 vortec heads. Chamber is almost identical, they use the 305 valve sizes, but share the 350 vortec ports. They flow like 230 CFM instead of 239 like the 350 ones do. A friend of mine put some on his 400(drilled the steam holes) in his montecarlo and it runs awesome.
eightsixseven
Dec 16, 2024 01:50 PM
