Normal engine vibrations
Old Feb 3, 2005 | 06:27 PM
colonboy14's Avatar
Car: Trans Am
Is it normal for a 305 to start vibrating around 4500 RPM? And by vibrating, I mean before that, there's nothing, but around 4500 it starts to vibrate slightly, nothing major.
Old Feb 3, 2005 | 06:49 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I had the same thing in my 350. At around the same RPM. When I pulled the engine, I found a broken motor mount which was part of the problem. I also found out later that my flexplate was shot. Could also be your problem, but I'd replace the mount first and see what that does.
EDIT: I see you run a manual tranny ... ok ... flywheel
Old Feb 3, 2005 | 07:32 PM
colonboy14's Avatar
Car: Trans Am
I have poly mounts, could this just be transmitting the vibration more?
Old Feb 3, 2005 | 07:36 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Perhaps, also check the tranny bolts. An old oldsmobile I had vibrated somewhat like that and found all but 2 bolts were loose.
Could be many things, from the clutch, flywheel, balancer, loose bolts, motor mounts, etc. Just have to narrow it down if it bothers you that bad. Mine wasn't very noticable. But there.
Old Feb 3, 2005 | 07:37 PM
colonboy14's Avatar
Car: Trans Am
Doesn't really bother me, I just want to make sure that nothing is going wrong.
Old Feb 3, 2005 | 07:53 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I suspect that your poly mounts might be the cause or helping the cause. I replaced my tranny mount with poly and it vibrates like mad now.
db057
Aug 22, 2015 08:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 12:07 PM
