timing chains: is a comp cams double roller a TRUE roller?
Old Jun 24, 2001 | 06:25 PM
james_fearn's Avatar
I want to replace a timing chain with a good roller setup. I'm looking at the comp cams Hi-Tek roller setup ( p/n 3136) for my roller cam and cloyes roller design. I don't know if a roller is a roller of if TRUE is a marketing gimic. I know they are both great chains but the comp cams chain is cheaper and still etter than a the factory chain.
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jun 24, 2001 | 09:21 PM
SUPER-SPORT-CHEVY's Avatar
Well lined up a comp true double roller chain with a dynagear double roller. One cost 110$ and one was 16.99$ The only difference was the comp's chain was a little better quality.
SSC
Old Jun 24, 2001 | 09:36 PM
Guest
Guest
Posts: n/a
I'd stay away from Dynagear personally.. but anyway
Yes, the 3136 is a true double roller timing chain, says so in the catalog. FYI its for the 87-up factory roller cam blocks.
Old Jun 24, 2001 | 10:25 PM
that's the one I want. I have a new 87-up shortblock I'm using w/ a ZZ4 cam.
James
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
