Throttle response weak from a stop ?
Old Jun 24, 2001 | 11:12 PM
83_TA's Avatar
Just wanted to get a couple of other opinions..
I have a fresh rebuilt 305, all new MSD ingnition, coil & distributor.. New edelbrock 1406 carb..
From a stop if I get on the gas hard, my car just has no pull it boggs down.. If I let off the gas & only use 1/4 throttle it goes fine.. Once I get going, if I floor it there is no problem..
Someone told me it sounds like the cat might be clogged up..
Does this sound like it might be my problem?
[This message has been edited by 83_TA (edited June 24, 2001).]
Old Jun 25, 2001 | 01:30 AM
83_TA's Avatar
Can anyone offer an opinion?
Old Jun 25, 2001 | 08:30 AM
irocbsa's Avatar
I think you may have another problem. A clogged converter will typically prevent the engine from even taching up to anything higher than a couple thousand RPMs. If you want to see if its clogged, get up under the car and bang on the cat with a mallet. If it rattles its shot.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 25, 2001 | 02:29 PM
Guest
Guest
Posts: n/a
Its not the cat, otherwise if you floored while the car was moving it would do the same thing.
Its a timing or fuel issue. Since you have an aftermarket carb and dist. on there I'll throw both at you.
The pump shot is probably too much. You may also have too large of jets and/or rods in the carb. Do you know what size rods and jets are in there now?
If its timing, its getting too much advance pulled out by the vacuum advance (if I remember correctly).
Definitely a tuning issue.
Old Jun 25, 2001 | 02:46 PM
Bort62's Avatar
I have had similar problems with the 1406's before, and I belive it was an Overly large pumpshot. This was on a 305 as well and it did exactly as your describe...
How is throttle response from a Roll ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
rsrookie
Sep 5, 2015 07:08 PM
Kenwood
Sep 4, 2015 05:50 PM
