SLP Headers? What problems have you come across?
Old Jun 25, 2001 | 10:11 AM
BrianB's Avatar
Thinking about getting these for my 88 GTA. I have heard of people having problems with them fitting, and getting hot. What kind of problems have you encountered if any?
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
Old Jun 25, 2001 | 11:16 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have the 1 3/4" off-road SLP headers.
I had to cut the y-pipe because it was too wide. Welded it back under the oil pan.
Also the header contacted the steering shaft, no real problem there.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jun 25, 2001 | 11:20 AM
custman87T/A's Avatar
I have the SLP 1 5/8 and a catco cat with an SLP catback and the only problem I had with them was the SLP cat conector that I purchaced with it didn't give a good fit to the catco cat, I purchaced a 3" stainless band clamp and it worked out fine. I wish I had the money to get them coated but even with the mild surface rust color they look good. The main pain in the a** is removing all of the stock exhaust and air pipes, after that it was a piece of cake.
Old Jun 25, 2001 | 03:53 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I purchased the 1 5/8. The only problems I have are the bolts that came with the kit and the Y-pipe. I plan on replacing the header bolt with allen type heads. As far as the Y-pipe, it barely clears my SFC. Noticeable throttle responce since replacing the iron headers. SPL headers and Borla exhaust makes a good combination.
Street Lethal
Apr 30, 2019 12:14 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
