Vader Help !!
Old Jun 24, 2001 | 07:08 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Vader Help !!
Vader:
Well I did like you said and it still would not throw a code for me. It will not idle again and when I hold the throttle open enough to get it to idle I am getting 12* BTDC on the timing.
Any ideas
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 24, 2001 | 08:32 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You may be waiting a long time asking for only one person. You don't think with 20,000 registered members he's the only one that can help you?
tisk, tisk.
Old Jun 25, 2001 | 02:19 PM
Well if you would have taken time to read down then you would have seen he has been helping me with a prior problem. Now if you have some input let me know if you don't then I am down to 19,999 to help right?
Brian
1989 Camaro RS
Old Jun 25, 2001 | 06:26 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by Brian Felts:
Brian
</font>
I don't see anything on this thread that identifies the problem your having - other than your attitude (which is going to need adjustment if you expect to get much help in the future).
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
GTAlover
Sep 19, 2001 09:03 PM
Timmys88Z
Aug 1, 2001 12:21 PM
