car barely running...Help!
Old Feb 6, 2005 | 07:53 PM
sk8runeg's Avatar
Car: 1998 Trans Am WS6
Transmission: M6
I just bought an 86 IROC with a 305 TPI H.O. engine. The car, however, has some problems:
1) When I am stopped, and I try to start going, the car bucks while misfiring continuously, then after a couple seconds of that, it takes off.
2) When on the highway, I was doin about 70, and when I floored it, it slowed down as if it lost all power, but if I only put the pedal halfway, the car would go OK.
So far I've replaced the spark plugs, wires, dist cap, and rotor. I have a timing light, but should be a last resort.
Also, i can hear some sort of a motor coming from the back of the car every time it stalls on me. It sounds like it could be the fuel pump or sumthing.
Wat could be the problem???
Thanks for the help
-Scott
Old Feb 6, 2005 | 08:11 PM
z92maroo's Avatar
Car: 1992 RS T-Top
Engine: 305TBI, Stroked LT4 @ Machine Shop
Transmission: 700R4, Built 2004R going in w/LT4
missfire
wellll... 2 things come to mind; intake leak, or egr prob. Use some carb cleaner 'round all intake gaskets, and see if your idle changes, or have your egr operation checked. Dunno, but hope this helps!
Old Feb 6, 2005 | 08:26 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
EGR should disengage at full throttle so it could be something with the Egr control valve. im thinkin something with the maf sensor or something like that. Something is not tellin the car to add fuel and its bogging out, Could also be a throttle position sensor. but i think that would affect it at idle and while driving. Is the trans downshifting when you punch it? theres a few things this could be.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
Omega
Aug 10, 2015 12:46 PM
BrianI
Aug 9, 2015 11:52 AM
