Odd starter problem
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
Odd starter problem
I have a question about this weird starter bolt holes. It's and older 350 but it only has hole for the starter in the postion for the bigger flywheel. now i have heard that this is only like this on 327. i would like to know if this is true or just a myth. and if it could be like 283 307 or 327 thing. can someone please shine light on this subject.
Transmission: 4L80E/4L80E
First, get the casting # off the block.
Second, 283's and a good portion of 327's had small journal cranks. Check www.mortec.com for details.
Finally, only being drilled for one pattern isn't too uncommon.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
db057
Aug 11, 2015 10:11 PM
