Any better moving the MAF closer to the air filter to read cooler air?
Old Jun 24, 2001 | 06:04 PM
BrianB's Avatar
I am putting a custom ram air setup on my 88 GTA. I am running it under the car to a K&N Cone Filter. I was just curious if it would be better to move it closer to the air filter or leave it in the factory spot right near the radiator?
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
Old Jun 25, 2001 | 12:23 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what's up BB?i think i'm going to go with this set up.PVC is real cheap(less than $4 a peice)
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 25, 2001 | 09:56 AM
BrianB's Avatar
I am taking mine up to Tri-State Muffler to get a piece of 3" Aluminum exhaust pipe custom bent to run underneath of the car with some sort of scoop. It will be pretty sweet, hopefully it will help.
Old Jun 25, 2001 | 04:12 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There'd be no merit to having the MAF read colder air. There is merit to keeping the MAF as close as possible to the TB, otherwise you are introducing more lag between when the engine starts pulling air, and when the MAF sees the increase.
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 25, 2001 | 06:49 PM
jms's Avatar
jms
A hint to you guys looking to build your own air intake system.
Exhaust pipe is measured on the outside of the tubing.
PVC (and water pipe) is measured on the inside.
Therefore - a 3" exhaust pipe ends up being about 1/4" smaller inside than PVC.
Just a free "tip".
jms
Old Jun 25, 2001 | 07:55 PM
Bort62's Avatar
Goood Point.
Just to be a B i t c h, thats also not PVC.
Its ABS.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 25, 2001 | 09:12 PM
BrianB's Avatar
What is ABS?
Old Jun 26, 2001 | 01:12 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
The plastic pipe is 3.5" o.d. anyway, so you may as well use 3.5" exhaust pipe with rubber reducers at the MAF. Here's what K&N had to say about intake pipe diameter:
"Dear customer,
Engine size and max RPM is what determines flow rate. The bigger the motor and the faster it turns, the more air it needs. On a small block I would go no bigger than 3.5" to increase velocity (air speed) and reduce turbulence.
Thanks for asking, Rick"
-Greg
'85 Trans Am - WS6,TPI:
Original owner, original paint/engine/interior, plus the usual bolt-ons
[This message has been edited by Greg '85 T/A (edited June 26, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
perZ
Aug 15, 2015 01:17 PM
