While driving, Radio and check engine light flash on and off
Old Feb 8, 2005 | 01:15 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
82 Trans Am, LG4, Q jet
After driving for around 10-15 minutes from warm up, my radio starts to turn on and off. Soon after, my check engine light flashes 3 times (I think) with it. The motor was running fine.
I just took out all of my smog pump equipment, and taped up a connection from the computer a few days ago, and did not have a problem in the meantime. What's going on?
Old Feb 8, 2005 | 06:45 PM
sellmanb's Avatar
Car: '86 Berlinetta
first check for trouble codes stored in the computer.
after that, once you find nothing there, follow the grounds from the radio back to where it grounds at. Clean it off, and any other grounds you have around the area... sounds like a ground loop.
Old Feb 8, 2005 | 09:41 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
After driving it home, the motor warmed up to just below 160, and radio turns on and off, check engine light turns on and off, then I notice the tach says 1600 rpm, when I can hear it idling. With my blinker on, the tach goes up a few hundred rpm insynic with the blinker. When I turned the heater on, the fan was not working to well, and the tach went up to 4 grand, while it was really around 1500. I park at a garage and when I try to start it 10 minutes later, the battery is dead.
The mechanic said it's most likely the alternator.
Old Feb 8, 2005 | 10:36 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had a similiar problem. My radio would randomly go on and off, and so would the SES light. Turned out one of my battery cables came loose and would connect and disconnect.
Old Feb 9, 2005 | 09:37 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The problem was the wires on the back of the alternator were corroded. After some cleaning, it works well.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
