car won't start....occasionally
Old Feb 9, 2005 | 10:12 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
hey fellers....okay, latly my problems occured more than ussual. the first time this happened was several months ago. didn't occur agian till about 4 days ago. then it happened agian on tuesday, then agian tonight. each of these times it been only once, not reoccurent. anyways...my car will not start. it will crank over just fine, but there will be no fuel. the injectors won't fire. if i come back and try agian about ten minutes later, it will start right up, no problem. anyone heard of a problem like this? or what could be the cause it?
Old Feb 9, 2005 | 10:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my guess is a bad fuel pump.
Old Feb 10, 2005 | 11:28 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i just replaced my fuel pump
Old Feb 10, 2005 | 07:27 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
any ideas?
Old Feb 12, 2005 | 03:29 AM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
Does it allways do it after its been driven and parked then you come back? or cold also? My moms 84 buick allways did that when it was hot.. It was the ignition module in her case.
Old Feb 12, 2005 | 01:48 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Basically had the same problem here awhile back, car would never start on the first try, you could crank it over for 5 minutes the first time if you wanted to and it wouldn't start , although i never had to wait 10 minutes, i'de just have to try the second time and it would fire up ,plus i'de have to work the throttle to start it..............bought a MSD 6A and haven't had a problem since, starts like it should now too, don't have to work the throttle anymore.
Old Feb 12, 2005 | 06:01 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
ignition module is fine, i replaced a while back, the injectors don't fire when it happens. it very rarly happens. like i said, its only happend a couple of times. im not to worried about it, since it hardly ever happens, but i thought i would try to find out what the problem is, incase the problem escillates.
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
kyle5647
Aug 7, 2015 03:08 PM
