Anybody with Desktop Dyno, Please Help
Old Feb 11, 2005 | 11:09 AM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
I recently switched my 87 Camaro L98 from TPI to Carb. The car is not a daily driver and I want to get as much out of the engine as possible. I have a little bit of money to spend and want to use the following set up. Can someone who has a desktop dyno or other program give me an estimate on horsepower?
Engine: L98 recently rebuilt with stock bottom end.
Heads: World Torquer S/R, 2.020"X1.600" valves, 76cc intake runners, 1.25" single spring.
Intake: Weiand X-celerator single plane, 2000-6000 RPM power band.
Carb: Holley 600cfm Double Pumper.
Cam: Crane Powermax adv. dur 284/292, dur @ .050" 222/230, .509/.528 lift, 112 LSA, power band 2500-6000RPM.
Trans: TH350 with kit.
Converter: B&M Holeshot 3000.
Gear: 3.73.
Thanks in advance for the help!!!
Old Feb 11, 2005 | 11:35 AM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
On desktop dyno 2000 I got the following numbers with 9:1 compresion:
with stock exhaust: 325hp @ 5500 rpm torq 346 @ 4000rpm
smalltube headers with mufflers:
366hp@ 5500 rp torq 395 @ 4500
The program isn't so specifiic that it differs from one single plane to another. THa cam numbers like lsa cant be adjusted either. So in reality you might get a bit more than this.
Old Feb 11, 2005 | 11:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sure they can, you need to enter the opening and closing events separately.
Old Feb 11, 2005 | 12:24 PM
87camz28's Avatar
Thanks Tilstad,
I have most of the parts listed above from collecting parts over the years. I wanted to reuse them so that I could use the rest of the money I had saved up on painting my car. I figured somewhere around 340 hp, but wanted to have someone double check me.
Thanks again!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
