Vacuum issue?
Old Feb 11, 2005 | 12:17 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Vacuum issue?
I do not have my A/C hooked up, I don't even have a plug on the inlet pipe near the firewall. Do I have a vacuum leak because of this?
Old Feb 11, 2005 | 06:09 PM
Vader's Avatar
Probably not. The source for the HVAC control vacuum is the engine. There is no "return" line.
Old Feb 11, 2005 | 06:44 PM
Car: 1987 Iroc-z
I got 1 line for vacuum booster and one line for FPR, what is the third line for?
Old Feb 11, 2005 | 08:23 PM
Vader's Avatar
Just behind the vacuum hose bibb for the FPR is another that is supposed to be connected to the HVAC/cruise vacuum supply:
If there is no line or cap there, you WILL have a vacuum leak. I thought you were asking about abandoning the line at the firewall.
Old Feb 12, 2005 | 01:28 PM
Car: 1987 Iroc-z
Thanks for info. My line is hooked up so thier shouldn't be a Vacuum leak. Just thinking of capping it of cuz I am deleting my AC. I have a Superram so things look a lot different.
Old Feb 13, 2005 | 10:38 AM
Durango_Boy's Avatar
Car: '98 Durango, '77 Vette
Another possibility to consider is in your throttle body. If the butterfly pin or throttle pin that go through the housing are loose at all you could be leaking vacuum from there. How much or what effects that would have I don't know...but 'm told those moving parts wear easily, and without a rebuild they can leak pressious vacuum.
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
