tach problem
tach problem
i have a 1985 lb9 that somtimes at idle the tach will jump up to 4000 rpm but the engine is actually idling. this also sometimes happens while crusing between 1500-2000 rpm, tach jumps up to 4000 rpm but the engine is still just crusing... what should i look at for problems first?
SD,
There is a tachometer buffer circuit module that conditiones the tach signal to a useable analog signal for the dash instrument.
Check the wiring at the distributor, the connectors for the instrument panel backplane, and the tach module. It should have a white wire from teh module to the inst. panel.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
Car: 4
Engine: 6
Transmission: 5
It's fastened to the back of the tach itself, inside the cluster.
A bad cluster ground will also cause strange behavior... if more than one strange thing happens at the same time, it would be time to start looking at things like that.
ICON Motorsports
ICON Motorsports
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
