One injector not working. (tbi)
Old Feb 12, 2005 | 04:58 PM
91rsklown's Avatar
One of my fuel injectors is not spraying. I checked all the fuses, and for just a second swapped the harness around between injectors and the one that wasn't working did and the one that did work didn't. so the injector is fine but something is wrong with the wiring. I checked the harness and it is fine and getting a good connection.
how should i check for voltage on the lines and what could possible causes be. thanks
Old Feb 12, 2005 | 06:02 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
$5 dollars says its a fuse, re-check them. I know you did already, but I had this same problem with my 89 toliet bowl injection.
Damn injector would stop spraying and the car would barely make enough power to go 25mph. And it'd do this on an off.
Turned out to be a fuse that kept buring out. I replaced it with a larger fuse.
Old Feb 12, 2005 | 06:21 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
HEY pennylessz28 replaced the fuse with a bigger one??? thats not good bro. there is a reason why that fuse is going out. it means that too much current is flowing in the wires. you should get that checked out before you mess somthing up, not just your fuse.
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Old Feb 12, 2005 | 09:10 PM
91rsklown's Avatar
and yes.....that might just have beared saying 3 times.
btw, i fixed it. a friend was watching the injectors when i swapped the wires and said they swapped, but when i checked the same one worked the other didn't
checked the ohms both read 1.5 so i cleaned the injector and blammo sprayo times 2
Old Feb 13, 2005 | 10:50 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
thats good that you fixed it. sorry for triple posting my computer jacked it up. just remeber not to put a bigger fuse then what it needs.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Jote4805
Aug 25, 2015 06:11 PM
justin57
Aug 20, 2015 07:05 PM
