i cant go over 65 HELP PLEASE???
Old Feb 12, 2005 | 10:12 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i have an 82 z28 with a 350 and holly elctric fuel pump, after it shifts into 3rd gear at about 2500 rpm i cant go any faster the engine starts to die and if i try to go faster my car shakes kinda violently it kinda looks like im tryin to drive a stick and im stallin it im thinking that maybe my fuel pump is crappin out and im not gettin enough fuel any suggestions would be graet thanks
Old Feb 12, 2005 | 10:17 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Has there been any recent work done to the car?
Some more info might be helpful.
Old Feb 13, 2005 | 09:13 AM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
its illegal to go over 65 anyways!!!
id check your fuel pump first
Old Feb 13, 2005 | 09:31 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
no it's not.. thiers posted limts by my house that read 70
Old Feb 13, 2005 | 10:04 AM
Vader's Avatar
Test the fuel pump output volume if you suspect it may not be keeping up. Route the pump output line (right at the carb if it's easier) into a fuel safe container. Power up the pump for 15 seconds. The pump should deliver at least a pint of fuel. If not, the pump may be at fault, or the filter may be clogging, or the fuel pickup/filter may have a problem.
If you get at least a pint in 15 seconds, start looking elsewhere.
Old Feb 13, 2005 | 12:01 PM
Car: 82 z28
Transmission: TH350
thank you for all your help im starting to work on it today ill try that to see if im getting enough fuel when i tried to drive it today it was alot worse i couldnt go over 50 maybe if i got up that fast
