Intake swap Q's
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Intake swap Q's
ok, I dont know alot about this particular engine .. nor the
car.
The intake has a crack very visible located near the thermostat
housing, and causing it to spit, bubble and overheat at times.
its LG4 305 w/ emissions compatible Q-jet.
my buddy is about to buy a Edelbrock Performer
intake here:
http://cgi.ebay.com/ebaymotors/ws/eB...category=36474
Will it have any problems?
were gettin a good deal over here in AZ for the same one.
Thanks guys!
car.
intake here:
Thanks guys!
Car: 4
Engine: 6
Transmission: 5
Shouldn't be too tough.... that one is about as close to a drop-in as any is. About all you'll have to do is come up with the right hose nipples and vacuum fittings and such. One trip to the hardware store with a carefully constructed list ought to fix you up.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
welll I can tell you just by looking you need a spread bore to square bore adapter plate
here.
http://cgi.msn.ebay.com/ebaymotors/w...sPageName=WDVW
here.
You guys are quik!
Thanks ... I can handle it
Thanks for the heads up.
Now whatta bout the hood? will I have clearence issues?
its a 87 T/A
Cause that intake is a bit taller than stock, plus the plate
which is what? .. 1/4inch thick?
its a 87 T/A
Engine: ls1, LB9
I think it will fit but, I am not positive, my buddie did this on his 86 ta but, used an aftermarket aircleaner so I can't say for sure. the factory one tends to be a little wider than what he had
No problems.
Were gunna ****** it up right now, buy some brews and get going.
I thank you all for the quik help.
will have her done in an hour or two.
ambainb
Apr 25, 2016 09:21 PM
