What the hell does code 36 mean??
Old Jun 28, 2001 | 02:09 PM
TwigBird89's Avatar
Can someone tell me what this means?? I would appreciate it immensely. I hope its not the MAF at fault cuz thats pricey... Thx
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
89 Firebird Formula
5.0 TPI T-5 WS6 G92 dual cat exhaust 3.42 posi New Grant signature series steering wheel (sweet), Accel cap, rotor and wires, K&N Filter.
1st ever run 15.1 @92 mph and w/ an exhaust I'll be in the 14s YEA BABY
Old Jun 29, 2001 | 01:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll go by your codes you listed and the engine in the car...would indicate that you're not getting a burnoff signal to the MAF, most likely cause would be a faulty relay, or poor connections, I'd start there before replacing a MAF.
If you have a DVM I could give you the test procedure to see if the relay is at fault or not.
Old Jun 29, 2001 | 02:58 PM
rondubbs's Avatar
chances are its just the 15$ relay on the driver side firewall..
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
