Car won't start. Won't even crank. Missing a wire???
Old Feb 14, 2005 | 05:25 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I rewired the car for my Commander 950 ecm and now it won't crank. No clicks or nothing. How many wires should go to the starter and which ones? I think I have all the wires connected for the actual "starter", but I only have one purple wire on the starter solenoid. Should there be another one? Where does it come from?
Thanks.
Old Feb 14, 2005 | 07:53 PM
Vader's Avatar
You need a purple wire on the smaller 'S' terminal, and a big, fat wire (from the battery) on the larger top stud. There should also be at least two smaller wires on this large stud, feeding the fusible links for the body/chassis wiring.
Old Feb 15, 2005 | 09:24 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Ya, I already got those hooked up. 1 main wire to bat. 3 fuseable links, to main stud. Then the smaller purple wire is going to the solenoid. The stock computer has been removed and when I turn the key I'm not getting 12+ volts to the starter. Is it just the igition after that? I didn't think there was too much else involved.
Old Feb 15, 2005 | 09:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Neutral safety switch
Old Feb 15, 2005 | 12:31 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
That was disconected a while ago. It would still start w/o the clutch before.
Old Feb 15, 2005 | 01:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check it?
Old Feb 15, 2005 | 01:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i already replied in your other thread...
starter disable relay... ground the black wire with a yellow stripe..
relay will click on, and car will start.
you can just bypass the relay if you wish.
midge54
Dec 27, 2019 04:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Exxon Limited
Aug 9, 2015 08:13 PM
