Max lift on stock 081 casting heads
Old Feb 14, 2005 | 04:16 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I have a 350 shortblock with a .480 lift cam. Can I bolt on a set of these heads without having the valve guides cut down?
Old Feb 14, 2005 | 04:53 PM
91Z28-350's Avatar
probably no. Take the heads to a shop and have them check it out.
Old Feb 14, 2005 | 05:56 PM
ZZsmpch's Avatar
The retainers were hitting the seals on mine at .460. Check them out carefully and don't assume anything. You can shim and use offset retainers to gain a little, but cutting them is a once and done deal and will give you what you need. Might as well cut them for bigger springs too.
Old Feb 14, 2005 | 06:12 PM
Car: 3
Engine: inboard
Ahh, so much for the $40 head swap- I have an 8.3:1 350 with 882's on it, and I am building a Edelbrock headed 406. But meanwhile I have this set of 081's sitting around, and a friend who said putting 305 heads on a 350 was "retarded" on another message board. SOOOOOO.......
I was going to just hose the goo off with some brake-kleen, lap the valves in the seats with some lapping compound and a suction cup, swap the Comp springs from the 882's on, a set of valve seals and a top end gasket set and just see what a difference it would make at 10.3:1 . I know I'd be going down from 1.94 intakes to 1.84's or something like that, but the CR would make a big difference. And I could show him my timeslips and ask him how retarded I am.
Anyway I'm not going to send them out to have the guides cut down and all that, not worth spending money on them just out of curiosity when I can put it into the new motor.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NWAsonoma
Aug 18, 2015 05:45 PM
anesthes
Aug 8, 2015 09:37 PM
