Just 1 "computer" in a 3rd gen, right ?
Old Jun 30, 2001 | 07:27 AM
GTA88's Avatar
My mechanic is telling me, unless I misunderstood him, that there is a "computer", and also a "circuit board", 2 different things, that he needs to examine on my car. He also says he needs to remove the dash to get to the "computer". He says he is going to take out a circuit borad and visually examine it for burned spots, and also run a diagnostic on the "computer". I thought the only "computer" was the ECM chip which is located right under the kick panel on passenger side, no need to remove dash. I also thought to check the computer, you just plugged a scanner into the aldl. No ?
How many computers / chips / circuit boards? Need to remove dash ? Need to remove computer / circuit board / chip to check them ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Jun 30, 2001 | 09:03 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
First, what is the problem your mechanic is trying to resolve? If it has something to do with your digital display, then the mechanic may have to remove part of the dash.
You are right that the ecm is under the passenger side kick panel and doesn't take more than 15 minutes to remove.
eightsixseven
Dec 16, 2024 01:50 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
