Diagnosing a bad ECM....
Old Jun 29, 2001 | 04:27 PM
Dave M's Avatar
Anyone know how I can test to see if my ECM is good without swapping in a new one. How can I test the existing unit? My friend jolted himself on the altenator while finishing up a header install and the car won't start. I've tried every possible fix except the computer. Any help here would be appreciated.
Dave M
88 GTA
Old Jun 30, 2001 | 11:45 AM
Dave M's Avatar
ttt
Old Jun 30, 2001 | 11:56 AM
Vader's Avatar
Dave,
When you first turn on the ignition, watch tyhe MIL lamp. The light should flash on briefly, then off briefly, then back on. It should remain on until the engine is running. If the lamp does not flash once like this, the ECM is not passing the initial self-diagnostic routine and may have a problem.
Make sure the lamp comes on. If it doesn't operate at all. you may need to check the ECM/fuel pump fuse.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
Magman
Sep 12, 2015 11:55 PM
