Is there a special tool for removing the o2 sensor?
Old Jun 30, 2001 | 07:03 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I was wondering if there was a special tool for removing the o2 sensor? Can I buy it at the auto parts store? Is it cheap? I know the sensor has a wire going to it, so I can't use a regular socket. And I don't think I can fit a open end or Box end in there.
Thanks dudes
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jun 30, 2001 | 07:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Easiest way i've found is to use the O2 sensor socket (has a groove in it to lay the wire aside...not necessary for removal, but saves mangling it on install) and use a 12inch extension, the ratchet comes out in front of the exhaust manifold and gives you plenty of acccess to get leverage on it...BTW, I used 1/2inch drive for it.
Old Jun 30, 2001 | 07:39 PM
Vader's Avatar
WCGTA,
Since you're replacing the sensor anyway, clip the wire and use a standard deep socket. Apply extra anti-seize compound to the new sensor (they never give you enough) and install it with an open end or box wrench. They don't have to be really torqued, just enough to crush the metal gasket ring.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 30, 2001 | 07:41 PM
dtpmike's Avatar
adjustable wrench did it for me.
Old Jun 30, 2001 | 09:36 PM
NHcamaro's Avatar
get that socket that 8Mike9 was telling you about
Old Jul 1, 2001 | 08:53 AM
Engine: ZZ4 - 350
Thanks for the advice guys. I don't think my old sensor is bad, I am just changing it for peace of mind. Who knows when the last time it was changed!
Thanks again
Mike
Old Jul 1, 2001 | 10:22 AM
Enkil's Avatar
If you're going to use the o2 sensor socket, be sure to wear some kind of mechanic's gloves.. chances are the socket will slip off a couple of times.
On the other hand, if you're going to cut the wire, make sure you're going to be able to get the sensor out. heh
It's also easier to do this with a warm engine, so maybe burnsleeves would help too.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
gta892000
Aug 11, 2019 11:16 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Eric-86sc
Sep 7, 2015 02:10 PM
