Elevation Question???
Old Jul 1, 2001 | 02:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I took a trip to the mountains (elevation 1200 ft), what are the affects on a carbureted car?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jul 1, 2001 | 02:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
On ANY internal combustion engine, the higher the elevation ... the thinner the air. Thus a car perfectly tuned for Sea Level will run richer in higher elevations.
1,200 feet is not a LOT (except if you are racing...then it matters). So for a quick trip, don't worry about it. If you were to live permanently there, then you may wish to re-jet your carbs one step leaner.
Overall, your car will always perform less at higher elevations than lower elevations too. That is why NHRA has correction tables for higher elevations comparing them to Sea Level. This is to to allow you to say "If my car goes xx.xx @ 1,200 feet. At Sea Level it would go zz.zz (if it was perfectly tuned to the condition it ran at 1,200 feet."
Humity has an effect too.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
