damn flapping ac belt
Old Jul 1, 2001 | 12:40 PM
85F-body's Avatar
when i turn on my ac in my car the belt starts flapping up and down and about a month ago it snapped and took out my power steering belt which took out the belt that goes to my harmonic balancer. so i changed all my belts and now it is still all ****ed up so what is wrong with my ac. Is it the compresser?
Old Jul 1, 2001 | 12:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is the belt tight??
Are all the acc. (alt, A/C comp., etc.) tight?? Any bolts missing...
Are there any broken/missing brackets...??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 01, 2001).]
Old Jul 1, 2001 | 02:34 PM
james_fearn's Avatar
on my 85 I have a problem w/ the AC belt taking out the radiator hose. I've had to place a protective cover over it to keep the AC belt from wearing into the hose. The AC and PS belts on our cars are a PITA to adjust, and even when properly adjusted are sloppy.
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jul 1, 2001 | 02:39 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I've never (knock on wood.. ) had a problem, I always tighten the P/S belt first, and make the A/C belt as tight as possible with a bar.
james_fearn: If you are hitting the hose with the belt, one of those 2 items is wrong. They should never touch.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Jul 1, 2001 | 03:08 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I had a similar problem. Nothing was wrong w/ the A/C compressor, and the belt was tight. It doesn't help that the belt has to span so far and turn such a high load. I just said the hell with it and converted to serpentine belt drive. Check it out, it took less than two hours start to finish. Serp setup
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 2, 2001 | 01:57 AM
85F-body's Avatar
i have a thing covering my radiator hose already i have had some damn problems with these belts. and ya the belt is tight and i am pretty sure that there are all the brackets and bolts and ****.
i think i might get a serpintine belt system too. hey gmtech there is one problem my ac compresser and altenator are on opposite sides of where they are in your link why is that? also how much did it cost for you belt system cause i want on now. o ya what is an underdrive system? i heard a lot about that too
[This message has been edited by 85F-body (edited July 01, 2001).]
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
