350 swap
Old Jul 1, 2001 | 06:39 PM
BenDoe's Avatar
350 swap
Will a 350 out of a 70-78 pickup fit in my car. I mean bolt holes, etc.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Jul 1, 2001 | 07:20 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
yes just chage the heads and you'll need a diifferent flywheel or flexplate as well as damper evrythiing else is the same
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60'
superram coming soon
Old Jul 1, 2001 | 09:22 PM
BenDoe's Avatar
why would i need new heads?
Old Jul 1, 2001 | 10:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 70-78 pickup will have low compression smog heads.
Old Jul 2, 2001 | 10:26 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
just slap the 305 heads on there... raise compression and still be able to use the stock TPI base...
later,
Chris
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
