2 problems that gotta be solved
Old Jul 2, 2001 | 12:12 AM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
k, well #1: I just got my car back from the shop after having my fuel pump replaced and my gas cap was missing. Could the lack of a Vacuum in the tank cause fuel starvation i.e. hesitation when getting on the petal and a kind of "chugging" when moving from a stop. #2: I've got an idle problem, very mild cam but she runs very lopey. wondering if leaking valve seals could cause this by fouling the plug.
Old Jul 2, 2001 | 07:24 AM
Enkil's Avatar
The gas tank/fuel system is pressurized, not, umm... vacuumized. heh
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 2, 2001 | 10:33 AM
Conv389drv's Avatar
Welll, if the gas cap were off for any length of time, then it's possible you got a good bit of moisture built up in the tank, and that would cause you some temporary problems, like the rough idle and stumble you described. And of course, check the plugs if you suspect any fouling.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
