Ignition Switch Wiring?
Old Feb 18, 2005 | 04:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I have a quick question for you guys...
I'm installing a push-button for starting the engine in my Camaro ('83 Z28). Its is a 5-speed. I have the button already installed, and I have one wire run to the yellow wire attatched to the switch on the clutch pedal.
My question is this:
A) Am I alright so far?
B) Where does the other wire go? I'm terrible at reading wiring diagrams, and haven't found a helpful one yet.
Old Feb 18, 2005 | 04:43 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
You need one wire with power on one side, and a wire to s terminal on starter solenoid from other side
Old Feb 18, 2005 | 04:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Any BIG RED wire. Easiest to find at the terminal strips that are above the parking brake release. In fact, there's probably extra terminals on that strip, that you could just plug onto; and not have to sodomize any wires at all.
If you have an empty fusebox terminal that's fused at 20A or more, with constant battery on it, that would also work.
Old Feb 18, 2005 | 04:54 PM
Air_Adam's Avatar
Great! RB saves the day again
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
