stripped bolts
Old Jul 2, 2001 | 12:23 PM
JunkHead84's Avatar
stripped bolts
i was just wondering what do u guys use for stripped bolts, i've tried everything except a torch only because i dont think it will fit in the tight area. thanx
Old Jul 2, 2001 | 12:41 PM
Z28Man's Avatar
Is it a head bolt??? What kind bolt is it? Besure you are using he correct socket, 12pt. and so on. You could spot weld a nut onto the head of the bolt if the head is rounded off. I had to do that on a flexplate bolt. Also heat is a great tool, torch even propane torch sometimes works if you can fit it. It's all a part of car crafting.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 6, 2015 07:28 PM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
