Rocker stud question.
Old Jul 1, 2001 | 11:22 PM
nelliesIroc's Avatar
I'm going to be installing screw in studs into a set of vortec heads. I have already removed the press in studs and my question is will I have to have the bosses milled to instell the screw in's or can I just tap the holes and install the studs and thats that?
Old Jul 2, 2001 | 12:00 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Tapping the holes and installing screw-in replacements are nothing but a poor mans stock replacement stud. Proper aftermarket studs need the boss machined down so that they can be installed.
Replacement studs are just a plain stud with threads at each end. They are not designed for spring pressures greater than stock. Aftermarket studs have a base so that you can tighten them down with a socket.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 2, 2001 | 12:53 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
...Replacement studs are just a plain stud with threads at each end. They are not designed for spring pressures greater than stock. Aftermarket studs have a base so that you can tighten them down with a socket.
</font>
So how do you tighten a "proper" aftermarket main cap stud? What hex collar? You can't fool me. I used to make, test, and qualify fasteners by the trillions, mainly for Ford, GM, and American Honda. The design deosn't really mean squat. Tensile testing and hydrogen embrittlement are the keys, and some of the "high-end" aftermarket bolts and studs fail miserably at standard ISO or ASME materails tests.
I'm only pointing out that you can't always make a generic statement that covers all the bases. Some of the collarless studs are superior in material to the "best" collared studs, if only because of the forging and cold flow stress lines created at the base.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
Ian Irvine
Sep 4, 2015 08:08 AM
