swap meet
Old Feb 20, 2005 | 05:42 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
swap meet
I am building my first race car and going to be going to a swap meet real soon to get some parts i need an engine block and looking for a tranny im interested in a bare 350 block or if i could find one would it be better to go with a 400 block and im looking at a th400 trans. i just want to know what to look for in buying a used block and trans. I am hopefully going to be looking at 500 -600hp and i was woundering if i should get a factory 4 bolt main or get a 2 bolt and get splayed caps.
thanks
Old Feb 20, 2005 | 06:24 PM
sellmanb's Avatar
Car: '86 Berlinetta
the 350's the 4 bolt mains are stronger (if you dont feel like paying for splaying..... hey, that kinda rhymed ). The 400's the 2 bolt mains are stronger.
If I was you, I'd try to find a 2 bolt 400, and stroke the engine... 500-600RWHP is easier to achieve with more cubes, of course
Old Feb 20, 2005 | 07:31 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what type of intake are you going to run? thats alot of hp for your first build.
Old Feb 20, 2005 | 07:40 PM
Car: 1987 iroc z
i'm not really sure yet i was going to put a 6-71 on it but since its my first build i was thinking of a high hp n/a set up i just want to get the block and go from there that was just a guess on the hp i just want a good 10-11 sec car i now i'm going to do it an all forged bottom some afr heads not sure which ones yet. and i really havent thaught about the intake cam or carb. But i was thinking about a tunnel ram do you think that would be a good.
Old Feb 21, 2005 | 12:45 AM
oil pan 4's Avatar
Car: 89 Firebird
2 bolt 400 all the way, I don't think you can go wrong.
The only reason I didn't get a 400 is becasue the stuff to build them is more expensive, plus I wasn't after that much power.
Old Feb 21, 2005 | 04:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
2 bolt main and splay it. Check the bore too. If I were dealing with that much power I would only deal with a virgin bore. Preferably an aftermarket block.
Old Feb 21, 2005 | 08:26 PM
Car: 1987 iroc z
i heard that a used 350 block could run from 50-200 bucks but how much more would a 400 cost.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
gwade12
Aug 8, 2015 08:17 AM
