fast idlin iroc!!!!!!
Old Jul 3, 2001 | 06:54 AM
88greyiroc's Avatar
i didn't know if all camaros had this problem or not but when goin down the highway when i am doin 70mph and let off the gas the rpms stay reving high at 2500 and instead of slowin down the car keeps going faster and the other night i went into a takeout and there was crush rock on the ground and the car was revin high and when i pushed in on the brakes the front tires slid across the rocks because the car was reving 1500 and still pullin. i was wonderin if anyone had any ideas on what that could be??????????????
Old Jul 3, 2001 | 07:17 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Sounds to me like a major vacumn leak. Have u performed any mods to your motor prior to the problem? Any check engine light codes? We need more info.
Corey
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Jul 3, 2001 | 08:26 AM
irocbsa's Avatar
Is your minimum air speed adjusted properly? Check the tech articles section for this procedure. Check for vacuum leaks like 86 said.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 3, 2001 | 09:00 PM
Z28Man's Avatar
Keep it simple, make sure your return spring is not trash. This happened to me, I just added another spring. Problem fixed!
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
redmaroz
Apr 25, 2017 07:14 AM
Fast355
Dec 2, 2016 06:33 PM
hayesaw0210
Aug 23, 2015 11:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
