How hard is it to install 2.73-3.73 gears?
Old Jul 2, 2001 | 10:31 PM
Irish_boy_305's Avatar
I'm about to get some gears, how hard are they to install?
87Camaro RS
305 carb.
K&N air filter
HyperTech Stage II chip
160 Thermostat
Autolite wires and NGK plugs
Old Jul 2, 2001 | 10:57 PM
Guest
Guest
Posts: n/a
Its something best left to someone with the experience and tools to do it properly. If you have access to the tools, thats a plus... but nothing beats someone who has done one before.
Old Jul 3, 2001 | 05:44 PM
82camaro's Avatar
Car: 82 camaro SC
Set up correctly gears will last a long, long time. Set up wrong and they may last only a block or two.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 4, 2001 | 10:07 AM
ede's Avatar
ede
they're not really hard to install they just require tools most people don't have or know how to use. it only takes a few hours to install a set of gears. i've read of people on here spending 500 or more for labor for gears. i'd guess the flat rate is under 2 hours. it's sort of a black art to most so they pay the big bucks for it.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 4, 2001 | 10:24 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Ring & Pinion.
Since you are going from 2.73 to 3.73, you will need to get "3" series gears for a "2" series carrier. A standard 3.73 will not work.
Don't forget to also replace your speedo gears.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
camaro11j
Sep 19, 2018 08:49 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
