Cant Get My Alternator To Bolt In!!
Old Feb 22, 2005 | 12:15 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
hey i recently bought a 1979 SBC 355 with a long water pump for my RS, swapped it in with all the bracketry off to i could fit it in easier and paint it all up fresh black. now i bought a chrome alternator bracket and a new alternator (http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting)
kinda liek that one. and i get get any thing to line up. is this that hard to do? any help? this is REALLY frustrating
Old Feb 22, 2005 | 01:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You need to make sure you have the correct brackets for the correct pump. A 79 truck application will have a long nose pump just like the one pre serpentine 3rdgens use although the brackets are slightly different to the point they will not interchange with stock clock posistion of the alternator. You will have to find the correct brackets for you application and since your using 79 truck peices it has to fit a 79 truck.
Old Feb 22, 2005 | 02:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a small block Chevy with heads that have the accessory bolt holes. It doesn't matter what sheet metal it was wrapped in before you got it, and it doesn't matter what sheet metal you're wrapping it in. It's a small block Chevy.
Put your 305 water pump and brackets and alternator on it. All that stuff will bolt right up, fit perfect, and work fine. Then send back the stupid chrome one that fits some other car. That's nothing but using your own money as the ammunition to shoot yourself in the shorts with.
Don't outsmart yourself or go out of your way to make extra unnecessary work for yourself.
Old Feb 25, 2005 | 08:00 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
so u recommend using all the stock TBI serp parts and just leave out the smog pump and ac ?
Old Feb 25, 2005 | 09:33 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
He's totally right, use the serpentine setup you have.. And keep the A/C as well, its cool... heh, its cool... lol
Old Feb 25, 2005 | 01:31 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you have a serpentine setup why would you even bother with the chrome or truck brackets? Serpentine is the only way to go unless its a SP or race car.
You will need to use your TBI's water pump or a water pump thats reverse rotation.
Old Feb 26, 2005 | 09:32 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
well i dont have smog or AC any more so what would i do?
Old Feb 26, 2005 | 09:02 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you do a quick search you will find the part numbers for smog and ac delete pullys. There not too expensive $20-30 a peice. Some creative TGO members have also found most interesting ways to delete those two items. I had the thread book marked but blew my system a couple days ago so now I dont.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
